Philco 60B Capacitor Question
What are the resistance readings from each contact of the rectifier socket to chassis?
The resistance from each rectifier plate contact to chassis should be equal. From the schematic, across the two plate contacts you should have about 275 ohms.
Philco 60B Capacitor Question - by Jamie - 10-24-2013, 12:22 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 01:43 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 03:23 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 04:28 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 04:43 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 04:59 PM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-24-2013, 05:04 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:14 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:21 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:46 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 06:05 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:13 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:25 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 06:42 PM
RE: Philco 60B Capacitor Question - by LASJayhawk - 10-24-2013, 06:50 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:55 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 07:02 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 07:09 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 07:14 PM
RE: Philco 60B Capacitor Question - by morzh - 10-24-2013, 08:13 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 06:23 AM
RE: Philco 60B Capacitor Question - by EricS - 10-25-2013, 08:21 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 09:14 AM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-25-2013, 09:17 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 10:17 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 10:28 AM
RE: Philco 60B Capacitor Question - by EricS - 10-25-2013, 10:52 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 10:55 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:03 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 11:08 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:14 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 11:20 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:56 AM
RE: Philco 60B Capacitor Question - by LASJayhawk - 10-25-2013, 12:11 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 01:02 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 02:20 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 02:44 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 03:25 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 03:37 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 03:47 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 04:00 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 04:05 PM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-25-2013, 07:15 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 08:15 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 08:37 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 09:07 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 12:16 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 03:00 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-28-2013, 04:28 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 05:10 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 12:37 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 01:24 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 05:59 PM
RE: Philco 60B Capacitor Question - by Jamie - 11-03-2013, 09:04 PM
