Found a Midwest Radio/Phono PICS ADDED
Wood looks solid! It is so much easier when you have a solid cabinet to restore.
RE: Found a Midwest Radio/Phono PICS ADDED - by TA Forbes - 10-25-2013, 12:06 PM
There are currently 7681 online users. [Complete List]
» 3 Member(s) | 7678 Guest(s)
