Schematic/Alignment Data Request
Thanks for the tips.
I normally pull schematics from a Rider's Perpetual, scan it high-res, and print it spanned out across 6 to 9 pieces of paper which I then tape together poster-sized and hang on the wall. The bigger and clearer the schematic, the easier the radio is to work on.
Schematic/Alignment Data Request - by N6MKC - 10-25-2013, 11:12 AM
RE: Schematic/Alignment Data Request - by N6MKC - 10-25-2013, 12:38 PM
There are currently 9922 online users. [Complete List]
» 1 Member(s) | 9921 Guest(s)
