Philco 640 Cabinet Refinishing Chronicles
#81
I've heard and seen both techniques too. My thoughts on that are to consider that the grain filler is always going to be very soft in comparison to the wood. You can let a small bit of grain filler dry for a week, and it will easily crumble between your fingers. So think about whats going to happen if you sand or steel wool after the filler dries. I just buff it very firmly with the burlap cloth, until the cabinet is almost shiny, then spray toner. But that is my technique, you gotta decide what you want to do.
RE: Philco 640 Cabinet Refinishing Chronicles - by Jamie - 10-25-2013, 03:05 PM
Users browsing this thread: 39 Guest(s)
Philco 91 Tuning Condenser
There are currently 10377 online users. [Complete List]
» 2 Member(s) | 10375 Guest(s)
