Two more additions
Jon
I am not sure why that is when it comes to plugging in an old radio. I had the same thing almost happen with a 10S470 (pictured) I picked up earlier in the year. At least that time the seller got the message.
Roy G
Two more additions - by RoyG - 10-22-2013, 08:05 PM
RE: Two more additions - by Radioroslyn - 10-22-2013, 08:17 PM
RE: Two more additions - by Jayce - 10-22-2013, 11:25 PM
RE: Two more additions - by RoyG - 10-23-2013, 01:33 AM
RE: Two more additions - by TA Forbes - 10-23-2013, 12:46 PM
RE: Two more additions - by PAradiogeek - 10-24-2013, 06:49 PM
RE: Two more additions - by RoyG - 10-25-2013, 08:06 PM
There are currently 9517 online users. [Complete List]
» 1 Member(s) | 9516 Guest(s)
