My new Zenith Trans-Oceanic
Looks nice and complete. Chassis appears very clean. The earlier ones are very cool. I have a G500 that I found at the flea market for $20 a couple years back. I had it electronically restored and now it works great. I need to redo the black material on the bottom since there was some moisture damage. I also want to put a couple of new hinges on the bottom. They are fun to listen to. Whenever I buy a radio via eBay, I always stress to the seller "please package very, very carefully to help avoid any potential postal damage". Sometimes it works and sometimes it doesn't. Nice find! Enjoy!
Craig R.
My new Zenith Trans-Oceanic - by 37silverstreak - 10-25-2013, 08:37 PM
RE: My new Zenith Trans-Oceanic - by morzh - 10-25-2013, 09:24 PM
RE: My new Zenith Trans-Oceanic - by VntgRads - 10-25-2013, 10:10 PM
RE: My new Zenith Trans-Oceanic - by BrendaAnnD - 10-25-2013, 10:51 PM
RE: My new Zenith Trans-Oceanic - by morzh - 10-27-2013, 01:59 PM
RE: My new Zenith Trans-Oceanic - by Radioroslyn - 10-27-2013, 02:32 PM
RE: My new Zenith Trans-Oceanic - by morzh - 10-27-2013, 04:29 PM
There are currently 5364 online users. [Complete List]
» 5 Member(s) | 5359 Guest(s)
AvatarAvatarAvatarAvatar
