91X vs 15X
That being said I would not turn down either one if they were offered to me at a reasonable price, as yet I do not own a Philco console with an inclined speaker board.
I don't know if Canadian Philco offered models in those types of cabinets, I have seen highboy and lowboy models from then of course, and chairsides. I haven't seen a Canadian Philco with a fully skirted cabinet older then 1934-35, and it was a 16X. Philco of Canada used to contract out their cabinet construction to outside firms so they may not have offered the full range given the smaller market and different tastes.
91X vs 15X - by Jayce - 10-24-2013, 06:09 PM
RE: 91X vs 15X - by Arran - 10-25-2013, 02:06 AM
RE: 91X vs 15X - by TA Forbes - 10-25-2013, 11:48 AM
RE: 91X vs 15X - by Arran - 10-26-2013, 12:13 AM
RE: 91X vs 15X - by Jayce - 10-26-2013, 05:04 PM
RE: 91X vs 15X - by TA Forbes - 10-29-2013, 01:52 PM
RE: 91X vs 15X - by 37silverstreak - 10-30-2013, 10:54 PM
There are currently 9760 online users. [Complete List]
» 1 Member(s) | 9759 Guest(s)
