41-280 antenna
I can only pick up one local station with the volume nearly full. the radio has been recapped and tubes replaced as needed. I am using the original antenna. Is there a way to use an external antenna to increase the reception? thanks for the help.
41-280 antenna - by Guest - 04-12-2008, 05:24 PM
[No subject] - by Texasrocker - 04-12-2008, 10:58 PM
[No subject] - by exray - 04-13-2008, 11:04 AM
41-280 antenna - by Guest - 04-13-2008, 04:43 PM
There are currently 9891 online users. [Complete List]
» 1 Member(s) | 9890 Guest(s)
