fuse for a 40-180?
Thank you for the info Icon_biggrin
can you tell me what mmfd on a cap stands
I know that mfd is for micro farad but MMFD ?
fuse for a 40-180? - by jerm - 04-12-2008, 05:08 PM
[No subject] - by 49Stude63 - 04-12-2008, 05:24 PM
[No subject] - by jerm - 04-12-2008, 10:51 PM
[No subject] - by Ron Ramirez - 04-12-2008, 10:58 PM
[No subject] - by Chuck Schwark - 04-13-2008, 11:14 AM
[No subject] - by jerm - 04-13-2008, 06:41 PM
[No subject] - by gary rabbitt - 04-15-2008, 10:15 PM
[No subject] - by jerm - 04-15-2008, 10:32 PM
Philco 91 Tuning Condenser
There are currently 10447 online users. [Complete List]
» 2 Member(s) | 10445 Guest(s)
