1936 624 6 Volt battery set
Wow.. I wasn't being emailed there were more replies to this post. I must've unchecked something.
I'm back.. this time with another snag.. I got everything up and running but I wasn't getting hardly any sound out of the speaker. started poking around and found no plate voltage on the 30 tube in the driver stage. I thought I'd tested the input Transformer but apparently, I either hadn't or had missed that the primary is open. Icon_sad
it's #69 on the schematic. philco part number 32-7454.
[Image: http://i1303.photobucket.com/albums/ag14...8bd1e2.jpg]
Any ideas on a replacement? it looks like it's a 10,000:10,000 audio transformer
I'd hate for this to be the show stopper.. it may be though. Would be a Shame as this has been a very time consuming restoration.
1936 624 6 Volt battery set - by bfrohwein - 06-17-2013, 03:57 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-17-2013, 06:02 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-17-2013, 09:23 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-17-2013, 10:43 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-18-2013, 12:21 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-18-2013, 03:00 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-18-2013, 03:29 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-18-2013, 08:57 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-18-2013, 09:50 PM
RE: 1936 624 6 Volt battery set - by Arran - 06-18-2013, 10:06 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 06-18-2013, 11:26 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-25-2013, 11:05 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 09-22-2013, 04:23 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 06:07 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 09-22-2013, 06:21 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-22-2013, 08:20 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 11:03 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 11:04 PM
RE: 1936 624 6 Volt battery set - by Arran - 09-22-2013, 11:42 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-23-2013, 09:39 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-23-2013, 11:18 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-24-2013, 01:46 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-27-2013, 11:41 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 10-28-2013, 05:27 AM
RE: 1936 624 6 Volt battery set - by Mondial - 10-28-2013, 08:50 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 01:21 PM
RE: 1936 624 6 Volt battery set - by Mondial - 10-28-2013, 04:38 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 08:07 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 11:40 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 10-29-2013, 04:46 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-29-2013, 08:10 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-30-2013, 06:25 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-14-2013, 01:39 AM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 12-14-2013, 03:00 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-14-2013, 03:17 AM
RE: 1936 624 6 Volt battery set - by Radioroslyn - 12-15-2013, 11:53 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-15-2013, 01:32 PM
Users browsing this thread: 19 Guest(s)
The speaker table error?
Philco 70 antenna lead
