Philco 650X shadowmeter in operation
Just a short vid showing the shadowmeter in operation after repair. Thanks to Ron Ramirez for his help. This would be the same for most 36 models using the oval bezel with a shadowmeter.
http://www.youtube.com/watch?v=_2ft_zQ6pK8
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 650X shadowmeter in operation - by BDM - 04-13-2008, 01:33 PM
[No subject] - by Ron Ramirez - 04-26-2008, 08:16 AM
[No subject] - by BDM - 04-26-2008, 04:44 PM
[No subject] - by Uffda - 04-27-2008, 01:02 AM
There are currently 8944 online users. [Complete List]
» 1 Member(s) | 8943 Guest(s)
