Philco 60B Capacitor Question
#50
The wires you moved away from the chassis edge were most likely the FIELD coil wires carrying the B+ voltage and not the voice coil wires.
As a further precaution, I would carefully check for cuts/wear in the insulation and slip sone heat-shrink on the those wires to be sure there is no future chance of another short in that area.
Chuck
Philco 60B Capacitor Question - by Jamie - 10-24-2013, 12:22 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 01:43 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 03:23 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 04:28 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 04:43 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 04:59 PM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-24-2013, 05:04 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:14 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:21 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 05:46 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 06:05 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:13 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:25 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 06:42 PM
RE: Philco 60B Capacitor Question - by LASJayhawk - 10-24-2013, 06:50 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 06:55 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 07:02 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-24-2013, 07:09 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-24-2013, 07:14 PM
RE: Philco 60B Capacitor Question - by morzh - 10-24-2013, 08:13 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 06:23 AM
RE: Philco 60B Capacitor Question - by EricS - 10-25-2013, 08:21 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 09:14 AM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-25-2013, 09:17 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 10:17 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 10:28 AM
RE: Philco 60B Capacitor Question - by EricS - 10-25-2013, 10:52 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 10:55 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:03 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 11:08 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:14 AM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 11:20 AM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 11:56 AM
RE: Philco 60B Capacitor Question - by LASJayhawk - 10-25-2013, 12:11 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 01:02 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 02:20 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 02:44 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 03:25 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 03:37 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 03:47 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 04:00 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 04:05 PM
RE: Philco 60B Capacitor Question - by BrendaAnnD - 10-25-2013, 07:15 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 08:15 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-25-2013, 08:37 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-25-2013, 09:07 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 12:16 PM
RE: Philco 60B Capacitor Question - by Chuck Schwark - 10-28-2013, 02:00 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 03:00 PM
RE: Philco 60B Capacitor Question - by Mondial - 10-28-2013, 04:28 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-28-2013, 05:10 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 12:37 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 01:24 PM
RE: Philco 60B Capacitor Question - by Jamie - 10-29-2013, 05:59 PM
RE: Philco 60B Capacitor Question - by Jamie - 11-03-2013, 09:04 PM
Users browsing this thread: 19 Guest(s)
There are currently 10171 online users. [Complete List]
» 1 Member(s) | 10170 Guest(s)
