Need help restoring my 40-180 - SUCCESS
Threads: 15
City: Anacortes, WA
If it's chocolate brown, I believe that's a purple stripe rather than pink, which would make... 47K ohm, yes? I don't have a chart in front of me and I'm a little rusty at decoding. And yes, I was quite surprised to find that resistor as well. (My secret weapon was several test leads in different colors... <<grabs yellow lead/gator>> "okay, I disconnected the yellow from *here*...")
Anyway, I've learned from the pros on here... "if it's a bugger to get to, replace it while you're already in that deep." Insert a timing belt joke here.
RE: Need help restoring my 40-180 - by DeckApe - 10-28-2013, 06:11 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 7036 online users. [Complete List] » 2 Member(s) | 7034 Guest(s)
