Rescued an 87 lowboy today.
I checked the cabinet for any clues as to when it might have been made. No dates, but I did find a stamp made into the wood claiming it was made at Philco Furniture, Plant 2. Not sure if that helps, but it is neat. With things already underway on this radio, I definitely need to locate a grill. I can see something was attatched behnd the main opening with wood screws and I can make out a faint square outline in the wood from where it was at.
Rescued an 87 lowboy today. - by Jayce - 10-25-2013, 08:40 PM
RE: Rescued an 87 lowboy today. - by Radioroslyn - 10-25-2013, 09:51 PM
RE: Rescued an 87 lowboy today. - by Arran - 10-25-2013, 11:16 PM
RE: Rescued an 87 lowboy today. - by Mondial - 10-26-2013, 05:10 PM
RE: Rescued an 87 lowboy today. - by Radioroslyn - 10-26-2013, 08:34 PM
RE: Rescued an 87 lowboy today. - by Arran - 10-26-2013, 09:28 PM
RE: Rescued an 87 lowboy today. - by Jayce - 10-27-2013, 09:04 PM
RE: Rescued an 87 lowboy today. - by Arran - 10-29-2013, 12:36 AM
RE: Rescued an 87 lowboy today. - by TA Forbes - 10-29-2013, 01:49 PM
RE: Rescued an 87 lowboy today. - by Jayce - 10-29-2013, 07:44 PM
RE: Rescued an 87 lowboy today. - by Jayce - 11-11-2013, 10:37 PM
There are currently 8770 online users. [Complete List]
» 3 Member(s) | 8767 Guest(s)
