Philco 640 Cabinet Refinishing Chronicles
#86
Got it. I wonder if it gives it more durability or affects the "depth" of the grain?
So many different ways...
Thanks
Tim
RE: Philco 640 Cabinet Refinishing Chronicles - by TimC - 10-29-2013, 09:50 PM
Users browsing this thread: 39 Guest(s)
Philco 91 Tuning Condenser
There are currently 10438 online users. [Complete List]
» 2 Member(s) | 10436 Guest(s)
