91X vs 15X
I've had my 15X for many years and apart from replacing the filter caps it's never been worked on and it plays beautifully! One of my favorite Philcos. I aquired a 91X cabinet from an old collector a long time ago and want to make a complete radio with it. I found a restorable 91 chassis on Ebay for it recently. Still need to find the dual speakers for it though. hopefully one day I will be able to play them head to head and see which is the better setIcon_lol!
Kevin
91X vs 15X - by Jayce - 10-24-2013, 06:09 PM
RE: 91X vs 15X - by Arran - 10-25-2013, 02:06 AM
RE: 91X vs 15X - by TA Forbes - 10-25-2013, 11:48 AM
RE: 91X vs 15X - by Arran - 10-26-2013, 12:13 AM
RE: 91X vs 15X - by Jayce - 10-26-2013, 05:04 PM
RE: 91X vs 15X - by TA Forbes - 10-29-2013, 01:52 PM
RE: 91X vs 15X - by 37silverstreak - 10-30-2013, 10:54 PM
Philco 91 Tuning Condenser
There are currently 9260 online users. [Complete List]
» 1 Member(s) | 9259 Guest(s)
