Philco B711
Nope, I didn't try alignment. Don't have the proper equipment. And I don't even have a tube tester but I did try tubes from another Philco with the same tube lineup.
Philco B711 - by pete7189 - 10-03-2013, 09:53 PM
RE: Philco B711 - by Ron Ramirez - 10-08-2013, 07:39 AM
RE: Philco B711 - by pete7591 - 10-26-2013, 05:40 PM
RE: Philco B711 - by Radioroslyn - 10-26-2013, 08:26 PM
RE: Philco B711 - by pete7591 - 10-31-2013, 04:39 PM
Philco 91 Tuning Condenser
There are currently 10210 online users. [Complete List]
» 2 Member(s) | 10208 Guest(s)
