Good morning, all
I am still working on my other project, but while I work the bugs out of the 48-1262, I have started poking around the inside of a 42-321 that I picked up at an antique store for $25 a few months ago. It looks complete though dirty, but it looks like a fun project since I have a lot of parts on hand. The cabinet is in very good conditon and should finish well.
Question: what kind of resistor is that left of center, the one that looks like a capacitor?
All the best for a great weekend,
42-321 - by ke5yum - 11-01-2013, 09:02 AM
RE: 42-321 - by ke5yum - 11-01-2013, 09:05 AM
