Replaced the capacitors but all I get is a hum
Do you have a service manual/schematic for it? You should use it to check voltages at the various test points. Also, make sure your resistors are within tolerance. If all that checks out someone can help you with more.
RE: Replaced the capacitors but all I get is a hum - by Warren - 11-01-2013, 11:56 PM
