Replaced the capacitors but all I get is a hum
Welcome to the Phorum!
You can get some schematic info here: http://www.nostalgiaair.org/Resources/535/M0013535.htm or here: http://www.audiophool.com/Philco.html
If you are not familiar with working on vintage radios you should read this first: http://www.antiqueradio.org/begin.htm
RE: Replaced the capacitors but all I get is a hum - by klondike98 - 11-02-2013, 05:38 PM
There are currently 8558 online users. [Complete List]
» 1 Member(s) | 8557 Guest(s)
