38-3XX - back panel?
Yes it did have a back when it was new. See this thread: http://www.philcoradio.com/phorum/showth...p?tid=6813
38-3XX - back panel? - by Rich K. - 11-02-2013, 07:04 PM
RE: 38-3XX - back panel? - by klondike98 - 11-02-2013, 08:10 PM
RE: 38-3XX - back panel? - by Rich K. - 11-03-2013, 08:12 AM
RE: 38-3XX - back panel? - by Radioroslyn - 11-03-2013, 11:23 AM
RE: 38-3XX - back panel? - by Rich K. - 11-03-2013, 01:00 PM
RE: 38-3XX - back panel? - by klondike98 - 11-03-2013, 03:12 PM
RE: 38-3XX - back panel? - by Rich K. - 11-03-2013, 04:30 PM
RE: 38-3XX - back panel? - by murf - 12-31-2013, 09:35 PM
RE: 38-3XX - back panel? - by Rich K. - 12-31-2013, 10:10 PM
Philco 91 Tuning Condenser
There are currently 10252 online users. [Complete List]
» 2 Member(s) | 10250 Guest(s)
