Replaced the capacitors but all I get is a hum
Thanks Jerry,
I am trying to respond but I think since I am new here my posts have to be reviewed first.
Andrew
RE: Replaced the capacitors but all I get is a hum - by Andrew Fleck - 11-02-2013, 09:27 PM
