Replaced the capacitors but all I get is a hum
That is correct.
http://www.philcoradio.com/phorum/showth...p?tid=5651
As you have now made more than two posts, Andrew, your posts no longer have to be approved. Welcome! Icon_smile
RE: Replaced the capacitors but all I get is a hum - by Ron Ramirez - 11-02-2013, 09:38 PM
There are currently 5795 online users. [Complete List]
» 2 Member(s) | 5793 Guest(s)
