Replaced the capacitors but all I get is a hum
Something to watch for on a 1942 set is the rubber coated wiring, it can be in bad shape and cause shorts. See Ron's discussion of this here: http://www.philcoradio.com/tech/wiring.htm
RE: Replaced the capacitors but all I get is a hum - by klondike98 - 11-02-2013, 10:33 PM
