Replaced the capacitors but all I get is a hum
Warren,
Unfortunately my tester will not measure resistance, but I will run out tomorrow and pick one up. Thanks for the tip. I will check them all once I get a better tester.
Andrew
RE: Replaced the capacitors but all I get is a hum - by Andrew Fleck - 11-02-2013, 10:43 PM
