Replaced the capacitors but all I get is a hum
I'm sorry let me clarify. It is a Fluke T+. It just measures voltage and checks for continuity. Since we are talking about electrical testers, does anybody have any recommendations on a decent tester. I would prefer to not keep buying these. I would rather spend more on features I might not need. I went cheap with the T+ because I thought it would be all I needed.
Andrew
RE: Replaced the capacitors but all I get is a hum - by Andrew Fleck - 11-02-2013, 11:11 PM
There are currently 9954 online users. [Complete List]
» 1 Member(s) | 9953 Guest(s)
