Zenith 5R312 voltages
Well,
(123/115)*6.3 = 6.73V, this is the answer for why the filament is 6.7V.
Your field coil is indeed 1/2 the resistance specified and this will affect the voltages some.
Zenith 5R312 voltages - by Buzz - 11-01-2013, 09:30 PM
RE: Zenith 5R312 voltages - by morzh - 11-01-2013, 10:38 PM
RE: Zenith 5R312 voltages - by Buzz - 11-01-2013, 10:42 PM
RE: Zenith 5R312 voltages - by BrendaAnnD - 11-01-2013, 10:48 PM
RE: Zenith 5R312 voltages - by Arran - 11-01-2013, 11:06 PM
RE: Zenith 5R312 voltages - by Mondial - 11-02-2013, 12:06 AM
RE: Zenith 5R312 voltages - by Buzz - 11-03-2013, 06:28 PM
RE: Zenith 5R312 voltages - by morzh - 11-03-2013, 10:44 PM
RE: Zenith 5R312 voltages - by Arran - 11-04-2013, 03:10 AM
RE: Zenith 5R312 voltages - by Buzz - 11-04-2013, 12:36 PM
RE: Zenith 5R312 voltages - by BrendaAnnD - 11-04-2013, 03:43 PM
RE: Zenith 5R312 voltages - by morzh - 11-04-2013, 08:52 PM
RE: Zenith 5R312 voltages - by Buzz - 11-04-2013, 09:58 PM
RE: Zenith 5R312 voltages - by Arran - 11-04-2013, 10:14 PM
RE: Zenith 5R312 voltages - by morzh - 11-04-2013, 10:22 PM
RE: Zenith 5R312 voltages - by Buzz - 11-08-2013, 10:43 PM
RE: Zenith 5R312 voltages - by Arran - 11-09-2013, 03:09 AM
