Identify this Emerson?
Yes, there were lots of them that had a similar style. Even some of their bakelites looked similar: http://radioattic.com/item.htm?radio=0270298
Identify this Emerson? - by Eric Adams - 11-04-2013, 10:15 AM
RE: Identify this Emerson? - by Phlogiston - 11-04-2013, 11:15 AM
RE: Identify this Emerson? - by klondike98 - 11-04-2013, 11:16 AM
RE: Identify this Emerson? - by Eric Adams - 11-04-2013, 11:33 AM
RE: Identify this Emerson? - by klondike98 - 11-04-2013, 11:39 AM
