Philco 46-350 in black
Well, my bad. I've had this radio for so long seems I forgot the proper model number. Its actually a 49-607. Both models look so much alike that I've been confusing them for all these years> I feel embarrased.
Philco 46-350 in black - by Jim Dutridge - 11-03-2013, 01:43 PM
RE: Philco 46-350 in black - by sam - 11-03-2013, 05:45 PM
RE: Philco 46-350 in black - by Jim Dutridge - 11-04-2013, 10:06 AM
RE: Philco 46-350 in black - by Jim Dutridge - 11-04-2013, 03:42 PM
RE: Philco 46-350 in black - by Ron Ramirez - 11-04-2013, 05:04 PM
RE: Philco 46-350 in black - by Jim Dutridge - 11-04-2013, 07:50 PM
Philco 91 Tuning Condenser
There are currently 7329 online users. [Complete List]
» 2 Member(s) | 7327 Guest(s)
