Philco 16B Restoration
Hi Arran,
Thanks for the tips.. all block caps done now..
Regards Rob
Philco 16B Restoration - by prado.au - 11-01-2013, 06:14 PM
RE: Philco 16B Restoration - by Arran - 11-01-2013, 10:17 PM
RE: Philco 16B Restoration - by prado.au - 11-05-2013, 03:30 AM
RE: Philco 16B Restoration - by prado.au - 11-05-2013, 03:51 AM
RE: Philco 16B Restoration - by prado.au - 11-17-2013, 05:11 PM
