2 for Deal! Philco 84 & 48-250
Yes, that chassis looks very original and in great shape. The tube shield even has a little metal cover on top which I have never seen before.
Did other Philcos using the square shields have these metal covers, or have they all been lost over the years?
2 for Deal! Philco 84 & 48-250 - by VntgRads - 11-05-2013, 12:11 AM
RE: 2 for Deal! Philco 84 & 48-250 - by VntgRads - 11-05-2013, 12:16 AM
RE: 2 for Deal! Philco 84 & 48-250 - by Mondial - 11-05-2013, 10:13 AM
RE: 2 for Deal! Philco 84 & 48-250 - by Jayce - 11-05-2013, 04:07 PM
RE: 2 for Deal! Philco 84 & 48-250 - by VntgRads - 11-05-2013, 05:27 PM
Philco 91 Tuning Condenser
There are currently 6088 online users. [Complete List]
» 2 Member(s) | 6086 Guest(s)
