Why are there two different electrolytic caps in my Hippo?
I just finished recapping two of these "hippo's" (both 1946 models), and, you're right, there shouldn't be that extra 50/50 cap. You can see the schematic here with what you should have: http://www.nostalgiaair.org/Resources/634/M0013634.htm Click on the little eye or floppy disc symbol to open the pdf file.
I'd eliminate that 50/50 and replace the caps per the schematic.
RE: Why are there two different electrolytic caps in my Hippo? - by NostalgiaRadioTime - 11-05-2013, 06:37 PM
There are currently 10528 online users. [Complete List]
» 3 Member(s) | 10525 Guest(s)
