Replaced the capacitors but all I get is a hum
Andrew, first step, if you have any new resistors, measure them on your meter to confirm that the meter is reading right. Yes possible that something like a 56 ohm is reading close to a meg if it an open wirewound or a really burned out carbon. Should you have some new resistors measure them to make certain you meter is working.
Regards, Jerry
RE: Replaced the capacitors but all I get is a hum - by jerryhawthorne - 11-06-2013, 07:40 PM
