Is this a Philco Grandfather Clock?
Thanks, I'll pass on it.
Is this a Philco Grandfather Clock? - by SteveJB - 11-06-2013, 07:34 AM
RE: Is this a Philco Grandfather Clock? - by SteveJB - 11-06-2013, 09:51 PM
Philco 91 Tuning Condenser
There are currently 10097 online users. [Complete List]
» 2 Member(s) | 10095 Guest(s)
