  • 1 Vote(s) - 5 Average
46-1201 model 128 restore and question
That looks like a 100pF (.0001 uf) tubular caramic cap. It is an RF bypass for the detector output. The radio will work without it so its not the cause of your no output problem.
You can reinstall that existing cap. It is a ceramic capacitor, very reliable and not subject to deterioration like the paper capacitors.
46-1201 model 128 restore and question - by tig1 - 11-07-2013, 07:47 PM
RE: 46-1201 model 128 restore and question - by Mondial - 11-07-2013, 09:28 PM
There are currently 10177 online users. [Complete List]
» 1 Member(s) | 10176 Guest(s)
