  • 1 Vote(s) - 5 Average
46-1201 model 128 restore and question
Now where abouts would that be? Icon_smile Looking at another schematic with test procedures it says to get B- at pin 5 of the 7B7. Is that the supply?
46-1201 model 128 restore and question - by tig1 - 11-07-2013, 07:47 PM
RE: 46-1201 model 128 restore and question - by tig1 - 11-08-2013, 08:38 PM
