restored 23x pics
They look fine to me - your picture width is 1024 pixels now, which is a good upper limit. Icon_thumbup
restored 23x pics - by Fred Taylor - 10-19-2013, 01:58 PM
RE: restored 23x pics - by TimC - 10-19-2013, 04:50 PM
RE: restored 23x pics - by dustyshoes - 10-19-2013, 05:14 PM
RE: restored 23x pics - by Jayce - 10-19-2013, 09:25 PM
RE: restored 23x pics - by Fred Taylor - 11-09-2013, 12:05 AM
RE: restored 23x pics - by Fred Taylor - 11-09-2013, 12:12 AM
RE: restored 23x pics - by Ron Ramirez - 11-09-2013, 07:35 AM
RE: restored 23x pics - by Fred Taylor - 11-09-2013, 08:51 AM
RE: restored 23x pics - by Fred Taylor - 11-09-2013, 09:55 AM
Philco 91 Tuning Condenser
