Well... a TV IS sort of a radio.
With a bunch of radios, I got a roundie tube, about 6", Motorola the other day. I haven't worked on a tube TV for 30 years. So, Brenda, you can continue to tell me what to do (or what not to do).
By the way, the picture tube HAD a light colored gasket where it met the front of the chassis. It took a while to figure out what this even was since it was a large pile of goop now. Anybody know where to get some sort of replacement. The picture tube is just hanging by a bracket near the yoke.
Well... a TV IS sort of a radio. - by BrendaAnnD - 11-09-2013, 09:09 AM
RE: Well... a TV IS sort of a radio. - by Phlogiston - 11-09-2013, 10:57 AM
RE: Well... a TV IS sort of a radio. - by Mondial - 11-09-2013, 12:04 PM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-09-2013, 03:03 PM
RE: Well... a TV IS sort of a radio. - by sam - 11-09-2013, 03:50 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-09-2013, 10:21 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-12-2013, 12:27 AM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-12-2013, 01:30 PM
