Bakelite cleanup
I have a nice little Zenith in a bakelite cabinet, cabinet is solid but has 2 issues.
Paint dots spattered on a good portion of the top, may be oil based. I have removed these before with warm soapy water and a soft brush, not coming off this time. Suggestions?
Also kind of a gummy stuff, adhesive maybe, on a couple of spots, thinking of using Goo Gone. Anyone have any experience with that stuff.
Cabinet is brown bakelite.
Thanks.
Bakelite cleanup - by Paul Philco322 - 11-09-2013, 11:58 AM
RE: Bakelite cleanup - by Eric Adams - 11-09-2013, 04:24 PM
RE: Bakelite cleanup - by Paul Philco322 - 11-10-2013, 12:26 PM
