Well... a TV IS sort of a radio.
That would mean that I would have to fix it. Well, OK, I'm in. How do we persuade him?
Well... a TV IS sort of a radio. - by BrendaAnnD - 11-09-2013, 09:09 AM
RE: Well... a TV IS sort of a radio. - by Mondial - 11-09-2013, 12:04 PM
RE: Well... a TV IS sort of a radio. - by Phlogiston - 11-09-2013, 02:39 PM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-09-2013, 03:03 PM
RE: Well... a TV IS sort of a radio. - by sam - 11-09-2013, 03:50 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-09-2013, 10:21 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-12-2013, 12:27 AM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-12-2013, 01:30 PM
