40-508 grill cloth
Hi
What you want is GRC-27 from Radio Daze.
EDIT: I erroneously stated earlier that Grillecloth.com no longer carried this pattern...turns out I was wrong; they DO still carry Pattern 27. It is omitted from their Flash animation showing "all" (actually most) of their patterns...which caused me to assume they no longer carried it. But if you look at his Palette #1, or at his price list, it is there.
I apologize for the error. It is great to know it is still available!
40-508 grill cloth - by philco phan - 04-18-2008, 11:52 PM
[No subject] - by Ron Ramirez - 04-19-2008, 09:12 AM
[No subject] - by philco phan - 04-20-2008, 04:42 PM
[No subject] - by philco phan - 04-23-2008, 10:09 PM
Philco 91 Tuning Condenser
There are currently 9978 online users. [Complete List]
» 2 Member(s) | 9976 Guest(s)
