The Big & The Small Of It--2 More Found Today
Later model Hi Fi RCA models with an Eye, are very cool.....Radio hanging in there till the end.
paul
RE: The Big & The Small Of It--2 More Found Today - by Paul Philco322 - 11-10-2013, 09:04 PM
