Story about Philco cabinet manufacturing
That was interesting to read. My 87 lowboy cabinet has 'Philco Furniture, Plant 2' stamped into the wood on the back, so it seems I definitely have one of the Red Lion produced cabinets. One of the two Radiola 66 consoles I owned had a Red Lion built cabinet, but I don't know if it was the one I kept or the one I traded to a friend.
RE: Story about Philco cabinet manufacturing - by Jayce - 11-11-2013, 06:31 AM
Philco 91 Tuning Condenser
There are currently 5141 online users. [Complete List]
» 2 Member(s) | 5139 Guest(s)
