40-216 Remote Control
Does anyone have any pictures of the wireless remote control that came with the Philco 40-216?
Oops, I see that I have inquired about what is referred to as the Philco Mystery Control. I found the information on the website. Now I know what it looks like. I will have to absorb all the data presented on the unit. I may have a chance to get a 40-216 that was equipped with the mystery control. I don't think the mystery control is with the radio any more though.
Thanks in advance.
40-216 Remote Control - by Joeztech - 11-11-2013, 05:25 PM
RE: 40-216 Remote Control - by ipwizard - 11-14-2013, 10:25 PM
RE: 40-216 Remote Control - by Joeztech - 11-15-2013, 07:26 AM
Philco 91 Tuning Condenser
