Scott 800B: The tuner
Jerry,
I have the power supply...
What I mean by four connections is that each coil has two terminals, with two coils per solenoid. So, there should be four wires (or, at least three, with one of them going to both coils), but I only see two wires hanging free.
Which Norman are we talking about?
The broken e-cap is on the tuner chassis, you can see the bottom of it just up and a bit to the left of the solenoid.
Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 08:58 AM
RE: Scott 800B: The tuner - by morzh - 11-11-2013, 11:57 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 03:37 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-11-2013, 09:56 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 10:39 PM
RE: Scott 800B: The tuner - by Arran - 11-12-2013, 01:03 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-12-2013, 01:43 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-14-2013, 06:04 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-14-2013, 01:13 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 10:43 AM
RE: Scott 800B: The tuner - by Chuck Schwark - 11-15-2013, 10:54 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 01:30 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 08:43 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 09:23 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 12:55 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 01:15 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 01:46 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 10:34 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 11:35 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-18-2013, 12:02 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 12:10 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 07:00 PM
