Well... a TV IS sort of a radio.
I'm just guessing here but I think one way to prevent an ion burn while setting a ion trap magnet is to set the brightness down as low as possible. I've never heard of this happening while setting the ion trap magnet but it obviously did in this case.
Well... a TV IS sort of a radio. - by BrendaAnnD - 11-09-2013, 09:09 AM
RE: Well... a TV IS sort of a radio. - by Mondial - 11-09-2013, 12:04 PM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-09-2013, 03:03 PM
RE: Well... a TV IS sort of a radio. - by sam - 11-09-2013, 03:50 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-09-2013, 10:21 PM
RE: Well... a TV IS sort of a radio. - by Arran - 11-12-2013, 12:27 AM
RE: Well... a TV IS sort of a radio. - by Jayce - 11-12-2013, 01:30 PM
