Knight Signal Generator Leads
Good morning all
A friend has let me borrow a Knight 650 Signal Generator with no lead(s). At first I thought that the connector on the front of the unit was an SO-239 but upon closer look, it is not. Can someone tell me what kind of connector this is and where can I get one? Also, could I improvise with alligator clips?
Knight Signal Generator Leads - by ke5yum - 11-12-2013, 11:19 AM
RE: Knight Signal Generator Leads - by BrendaAnnD - 11-12-2013, 11:39 AM
RE: Knight Signal Generator Leads - by ke5yum - 11-12-2013, 03:44 PM
There are currently 10549 online users. [Complete List]
» 2 Member(s) | 10547 Guest(s)
