Replaced the capacitors but all I get is a hum
#47
Yes Andrew, as Brenda indicated with the field coil open (disconnected) you will get no voltage anywhere but the rectifier. Need to have the speaker plugged in to give it a chance. The field coil is part of the speaker and the power supply.
Jerry
RE: Replaced the capacitors but all I get is a hum - by jerryhawthorne - 11-12-2013, 04:18 PM
There are currently 3949 online users. [Complete List]
» 1 Member(s) | 3948 Guest(s)
