Replaced the capacitors but all I get is a hum
#50
Morzh, you still can get a hum because of the pulsating DC flowing through the field coil. The resultant varying magnetic field induces a voltage in the voice coil which causes it to move.
Same concept as an AC induction motor
RE: Replaced the capacitors but all I get is a hum - by Mondial - 11-12-2013, 06:52 PM
