Scott 800B: The tuner
Chuck,
Not really sure they're using ferrite slugs in this, but that's one of the things I need to check out. Definitely will check for greenies. This is an interesting FM IF setup. The first IF primary is on the tuner and connected to the 1st IF secondary by a coaxial link. Amp chassis has two stages of IF amplification, followed by two stages of limiting and discriminator.
Jerry,
Thanks! That's a great idea, and I'll give it a shot. May have to buy a bunch of 0.1 disc caps, though, don't think the poly caps I have will fit in the cans.
Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 08:58 AM
RE: Scott 800B: The tuner - by morzh - 11-11-2013, 11:57 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 03:37 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-11-2013, 09:56 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-11-2013, 10:39 PM
RE: Scott 800B: The tuner - by Arran - 11-12-2013, 01:03 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-12-2013, 01:43 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-14-2013, 06:04 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-14-2013, 01:13 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 10:43 AM
RE: Scott 800B: The tuner - by Chuck Schwark - 11-15-2013, 10:54 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 01:30 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-15-2013, 08:43 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-15-2013, 09:23 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 12:55 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 01:15 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 01:46 AM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-17-2013, 10:34 PM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-17-2013, 11:35 PM
RE: Scott 800B: The tuner - by BrendaAnnD - 11-18-2013, 12:02 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 12:10 AM
RE: Scott 800B: The tuner - by jerryhawthorne - 11-18-2013, 07:00 PM
